MM2 - Brave New World - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: General Custom Mansions Area (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=4) +--- Forum: Free Uploading and Downloading (https://actionsoft.com/forum/forumdisplay.php?fid=19) +--- Thread: MM2 - Brave New World (/showthread.php?tid=2204) |
Re: MM2 - Brave New World - Freddy - 02-28-2023 3C2C3B32325E0 wrote: 16503 What happens if jack uses his multicolor key in this room?A good night brought me insight about this room that I am going to change. The wrong design almost sure doesn't lead to any kind of Jack stuck but there is a major BUT! Like it is now it is a guessing game and I pleaded myself to avoid that. So fixing may be expected. Edited: fixed (see images) and will be seen in the next version. Re: MM2 - Brave New World - Freddy - 02-28-2023 74405756564B320 wrote: ... in room 17605 ...More insight. The 4th giant spider missing the 4th eye ball looks soooo bad that I will fix this as well. But the moving platform ... :-X Edited: It wasn't that easy to force the 4th (always left) spider to eat the last eye ball. Depending from the moment of pulling the lever to open the trap doors and the position of the spiders and eye balls, it may be any of the 4 eye balls that stays alive. The solution I chose was increasing the speed of the eye balls from 5 to 14. Re: MM2 - Brave New World - Freddy - 02-28-2023 3626313838540 wrote: ...I think I am going to tear down the wall (Pink Floyd) between the left and the right parts of the room. An obvious opening for Jack to jump in both directions. Edited: fixed (see pic). Re: MM2 - Brave New World - Freddy - 02-28-2023 The other issues. 17300 I brought the delay between the jumps of the fish bones from 120 to 160, while one shield is still 'waiting' above the platforms. 16698 Easy fix. I replaced the ladder between 16699 and 16899. 16905 I added a shield on the bottom floor and moved a moneybag to the top floor. 17505 My bad. A typical hurry-to-post mistake. I should have known better! (Beatles) Re: MM2 - Brave New World - Freddy - 03-05-2023 The life of a designer is full of fun. Creating new rooms, polishing existing rooms, fixing reported mistakes. And troubleshooting ... Have a look at the image of room 17100. My Jack entered the room when the blocks were gold and at a certain point he arrived in the lower left corner. No silver block there, only a gap! My jack, as a test, walked into the gap and arrived on top of a purple door. See the picture of room 17300. To fix that I moved the purple door a little bit to the right to avoid that Jack falls on that door. New problem. At a new attempt my Jack walked again into that gap and fell dead at the left of the door, but before dying he touched the door and since he had a rainbow key the purple door opened! : ![]() I had no space enough to move the door more to the right because of the ladder. Thus: I moved the ladder, the door and the construction above that ladder. Result: in room 17100 I had a hidden platform that wasn't working proper anymore. ;D Just to say that some things take time. Version 013 is enclosed. There are now 16 secrets, 7 saves, more shields and $ 19.325 although I can't find $ 50 of them. :-[ All remarks are welcome. Re: MM2 - Brave New World - Freddy - 03-06-2023 Good morning, brell ! This morning I suddenly realized that room 16703 is still not wat we both want it to be. On the picture Jack came in from the left while the blocks were gold and is now standing on top of the silver blocks, ready to climb the ladder and start a thorough visit of the room above. But there are still two problems! 1. Jack may also leave the room immediately to the left and continue somewhere completely else. 2. Jack may do the visit above, but after returning to room 16703 he may go right, change the blocks back to gold and leave the room by retracing his steps. Both things don't lead to Jack-stucks but they are unwanted because leading to a guessing feeling or bringing up ideas of (large) backtracking. Solution. Part 1. In room 16703 the G/S-lever will be replaced by a (red) press button forcing the blocks to become and stay normal (= silver) and the most left silver block will be removed. The way out of this section will start with a ladder down in the bottom left corner of the room above. That is left of a closed grey door that must be opened with a lever that is behind the red door that had to be opened first! In room 16703 the one-way ladder down will replace the blue floating bricks in the upper left corner. Part 2. It will be absolutely necessary to make changes concerning the blue key. Because of the one-way issue it will have serious consequences when leaving the section without a key. Assume Jack opened the red door with the rainbow key, did not pick up the blue key and took the one-way ladder down, I think he is forced to do large backtracking into the purple area to change the blocks back to gold to be able to get the 'forgotten' blue key. (What is right now the same when Jack jumps down to left from the silver blocks without a key.) :o Edited Even after the changes there is more to think about. Take the same room 16703 with Jack on top of the silver blocks. There he makes a wrong movement and dies. When he came from the room above he reappears on the ladder and is able to climb up again. No harm. But what if he hadn't been up yet and reappears at the left entrance? If Jack has a rainbow key, he is at the very beginning of the blue area and has a lot of good alternatives. But he also may have a red key (a wrong or no key is also possible but a playing mistake). Then there are two possibilities. The red door in room 16704 is still closed and is Jack's new and only target. Or that red door is already opened. In that case the blocks have to be changed to gold again. And that means backtracking. Maybe a lot. ![]() Or I do much more changes like: - moving the G/S-press button to the room above; - replacing the silver blocks with solid blue bricks. Re: MM2 - Brave New World - brell - 03-06-2023 17499 is under maintenance and one of the reasons is because it felt to hard. The problem is the up and down going platform at the left that may go down in the lava. I am thinking of avoiding that with a solid ledge in the lower left corner and maybe also one in the upper left corner. That would help for the transfers as well. An obvious gap as a hint?! Interesting idea. I would dare to do that. Suits well with BNW! 17300 I will surely make the length of the intervals long enough. The shields are more a general issue. So am I going to remove almost all the covers of the shields because I want to give the players real shield information with the map. You finished with €17400 and 81% secrets. If you had a second save with $ 4.000, then you did find 6 secrets at that time. With 81% it seems that you are missing 3 of the 10 secrets from the blue area. Planning new attempts? 16703 A brief moment I was thinking of a G/S-lever in TZ1 but that would be a paradox with the concept of the blue area. Can you imaging all future Jacks running several times on and off to that lever? I am going to fix it till it works exactly the same as all other sections of the blue area. Re: MM2 - Brave New World - Freddy - 03-07-2023 [smiley=thumbdown.gif] I am really really sorry, brell. This morning I saw that I made an awful mistake. My answer on your latest post did overwrite yours. So your text is gone. And my text looks like it is yours. Pfff ... :-[ Re: MM2 - Brave New World - brell - 03-07-2023 No problem. Regarding 17499, are we talking about the same room? I was talking about the ghost platforms room in my post. There are no moving platforms in 17499. I was talking about the gap in the lower right corner from the ghost platform there to the conveyor belt. There is an opening in the wall to the right of the belt which gives a hint of a room behind but the gap is too big for Jack to jump. Re: MM2 - Brave New World - Freddy - 03-07-2023 Oops again. I was talking about an other room. There are three rooms that IMO may be too hard: the one with the ghost platforms, the one with the moving platforms and the one with sinking platforms and two eye balls. 'Your' room with the fish bones I added to that list. I certainly want to bring them all to a normal level. Concerning the missing secrets, my best suggestion is to keep searching. E.g. check the map for gaps when Jack is at the end of TZ2 thus before using any TGV-platform to the finish. That will give me an idea of the current hint-difficulty-degree. [smiley=dankk2.gif] |
