UNDERGROUND FORTRESS released !! - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: Discussions of approved MM1 and MM1 HD custom mansions (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=11) +--- Forum: Underground Fortress (https://actionsoft.com/forum/forumdisplay.php?fid=57) +--- Thread: UNDERGROUND FORTRESS released !! (/showthread.php?tid=773) |
Re: UNDERGROUND FORTRESS released !! - Windrider - 10-15-2008 Yes, think I jumped over the floor switch on the way in...then I did activate the switch in the first column. So....I have gone back to my last save and started from there. I managed to get through without becoming entombed again. Whew! Ok, now I am having the same problem that Lara was having. I'm stuckin room 15698 which I entered from the right. I have been the area to which she refers where the save is ( don't want to spoil) and activated the gold bricks on the left. I have the purple key and four green keys. But for the life of me I just can't figure out how to get from the first column on the right to the middle one....there doesn't seem to be an elevator. Now totally exasperated after my last ordeal......please PM me with how to get SOMEWHERE...Please! Re: UNDERGROUND FORTRESS released !! - Lara - 10-19-2008 Windrider wrote: Yes, think I jumped over the floor switch on the way in...then I did activate the switch in the first column. So....I have gone back to my last save and started from there. I managed to get through without becoming entombed again. Whew!You missed something at an earlier point in the mansion. Remember that those three blue columns run throughout a few mansion levels. Have a bit more of a nosy around... x Re: UNDERGROUND FORTRESS released !! - aquaMat - 11-01-2008 Today I have send an update of Underground Fortress to the admins. It should be downloadable pretty soon. It fixes the potential JS-situation mentioned by Windrider above. Also there are 1 or 2 small decorative enhancements. So even though there are no major changes, I recommend strongly that you should all download this new version 1.1. Re: UNDERGROUND FORTRESS released !! - Sharpie - 04-26-2009 Aquamat, I'm really enjoying playing UF. Playing it now that my skill level is finally able to handle it. ![]() But, is this a JS or how do I get out of here? As you can see, I don't have a green key to use below. Re: UNDERGROUND FORTRESS released !! - rose - 04-26-2009 This isn't a JS! You can get a level below and ou can get out to the left, where you came from. The green key is somewhere
Re: UNDERGROUND FORTRESS released !! - rose - 04-26-2009 rose wrote: This isn't a JS! You can get a level below and you can get out to the left, where you came from. Re: UNDERGROUND FORTRESS released !! - aquaMat - 04-26-2009 What Rose says is the truth, and nothing but the truth....!! ![]() Explore the area thoroughly is the best advice I can give you. (And by areaI mean not only the room you are in now....) There are cracks in the wall Some wise poet said that. Look under every stone. I said that. Re: UNDERGROUND FORTRESS released !! - Sharpie - 04-27-2009 Well, with no lives Jack died exploring that area. I have found where that green key is. But now I'm in Rm 15298 in a similar situation as Windrider was. I'm in the area to the right of the blue columns and can't figure out how to get out of this room. Re: UNDERGROUND FORTRESS released !! - Semi-Native - 04-27-2009 Catwoman, Jack is not stuck, there is a way out. Remember the way out is not always visible. Get up to the top. Re: UNDERGROUND FORTRESS released !! - aquaMat - 04-27-2009 Sharpie wrote: But now I'm in Rm 15298 in a similar situation as Windrider was. I'm in the area to the right of the blue columns and can't figure out how to get out of this room.Catwoman, is it possible that you still use Version 1.0 of Underground Fortress?? Only if this is the case you can be stucked.... If so, I strongly advise you to download the latest version of UF from the usual spot. If you are already using the update 1.1, you just need to go looking for the secret escape route ! 8-) |
