The Four Tubes - Printable Version
+--- Forum: Four Tubes, The (https://actionsoft.com/forum/forumdisplay.php?fid=99)
+--- Thread: The Four Tubes (/showthread.php?tid=718)
Pages: 1 2 3 4 5 6
Re: TFT > The Four Tubes - aquaMat - 04-07-2008
Thanks a lot, everybody, for all your nice & encouraging words !
I enjoyed building The Four Tubes a lot, probably more than any of my previous mansions (maybe because it was the first one that I sketched out on paper before I started to build).
I even thought about making an edited version for the Expansion Pack (should it ever appear) !?!
BTW, has anybody managed to end with all secrets (and all money) found, yet ??
Note: For 2 days now my hi-speed internet access is either very slow or not working at all (e.g. for this reply I had to wait 20 mins. until the page
materialized
So I probably won't be able to participate that much until the fault has been found and the speed is
back to normal
Re: TFT > The Four Tubes - arevn - 04-26-2008
Whee, that was so much fun!!! Congrats on a great mansion!
I only finished with 58% secrets, however. :-[ I couldn't figure out how to get into the last tube since my key was the wrong colour.
The order in which I accessed the tubes was (highlight to see):
Blue, red, and yellow, making green the tube I couldn't enter. I finished the yellow with a blue key that let me explore the second part of the mansion. Oh, and I did find the final yellow key, though!
ETA: I played again by accessing the tubes in a different order and was able to finished with 97% or so of the secrets. Yay!
Arevn
Re: TFT > The Four Tubes - Toybox - 04-28-2008
Am I playing an old version, or just missing something? I seem to remember a blatant lack of BBB for one of the tubes (that is, no
The Green Tube
announcement - although maybe it is another colour).
Re: TFT > The Four Tubes - aquaMat - 04-29-2008
@Toybox:
You are right. In the first (or first two) versions I accidentially ommitted the BBB for the green tube !
This has neem fixed in the meantime, although I'm not sure whether that update has already been released. (I'll check later).
@ arevn:
As I said before:  No matter in what order you travel through the tubes you will always be able to finish (= access the final section).
If you didn't in that one instance, I'm sure it had nothing to do with the
tube order
but was due to some other oversight of you (and I guess I know which).
The whole door/key color system is very logical, it works similar in every tube.
Re: TFT > The Four Tubes - Scout - 04-29-2008
Thanks for the fun game, AquaMat.
I have questions (as usual!). One of them seems to have been answered above; I only have the red tube left to access but have no red key, so assume that I missed a red key somewhere...
The other is - I think - room 14303 with the pillars. I'm just not getting where Jack is supposed to launch himself to from that vibrating brick. Have gone through more lives than I care to admit here, and would be grateful for a clue if you can do so without ruining it for the others.
Thanks
Scout
@ Scout:
Thanks for the nice words !!
As for your question:
You should simply try to get back to
safe ground
(e.g. the top of the column that has the
vibrating brick
in it) and from then on continue your way upward....
Does that help ?  (I'm not completely sure I understood your question correctly !?)
@ arevn:
Addition to my reply above:
In the meantime I have tried to duplicate your behaviour to find out what your problem might be.....  I sent you a PM about it.
However, starting with the BLUE tube is definitely just as possible as any other order.
Re: TFT > The Four Tubes - hawaii - 08-12-2008
Hello,
After the 4 tubes, in the next section.....room 13704....bottom ledge. How to open the grey door. I did it the 1st time, now I can't remember. It's been days & still I can't figure out how to open that darn grey door (just before the moving belt.)
Any suggestions? [smiley=embarassed.gif]
Re: TFT > The Four Tubes - aquaMat - 08-12-2008
Hi again, Missy,
there is no grey door in room 13704.... but maybe you are talking about the grey door in room 13504 (the room directly above it) ???
Other people have asked this question before....so maybe it helps if you check in the depths of the
Four Tubes
thread...
But I'll give you one hint:
The grey door can NOT be opened from the right side !!!
Re: TFT > The Four Tubes - aquaMat - 08-14-2008
I really can't understand why there are apparently a few people who have real problems with this room, whereas I (and probably most of the other players) find that area in TFT quite straight-forward.
Anyway, I give you one more hint:
As the grey door in question cannot be opened from the right side, it surely must be opened from the other, the left side.... An area you get to only a bit later in the game.
So when you are now RIGHT of the grey door in 13504, I advise you to simply forget it for a while and continue with what's left right of that door etc.
Should you be already LEFT of the grey door....well, then you only need to look for the hidden switch.
Did that help ??
Re: TFT > The Four Tubes - brell - 08-15-2008
Missy, there are NO glitches in any of the custm mansions.
Btw. Palace of Gore is located at the same place where you found Small Palace of Gore
