Tomb of Princes Easy Secrets - Printable Version
+--- Forum: Included mansions (https://actionsoft.com/forum/forumdisplay.php?fid=42)
+--- Thread: Tomb of Princes Easy Secrets (/showthread.php?tid=1928)
Pages: 1 2 3 4 5 6
Re: Tomb of Princes Easy Secrets - Semi-Native - 01-10-2012
It's not in the last section, it's somewhere in the middle. If I get a chance, I'll go through the game and post the room number later.
Room 15491 is where I'm talking about.
Re: Tomb of Princes Easy Secrets - B_Diane_Landon - 01-10-2012
oh I got those two early in the game before save 1. At save 1 I had 1. At save 2 I had 7. At save 3 I had 12. And that is since the first time I played the game. I cannot find another one. I went on to playing other levels because when you repeatedly play same one you start to memorize your path and keep repeating the same error if you have one.
Re: Tomb of Princes Easy Secrets - brell - 01-10-2012
The secret BDL is missing is in the end section of the mansion. As I said, in a room to the left of the long pole. There are some vines in this room.
Re: Tomb of Princes Easy Secrets - B_Diane_Landon - 01-20-2012
Still have not located the 13th secret. I have considered maybe it is the center pole rather than the far right pole. But no remaining secret found in any room in the last section. Game is no longer fun.
Re: Tomb of Princes Easy Secrets - brell - 01-20-2012
Diane, it is to the left of the center pole. It is in the second row from the top rooms and second room to the left of that pole. The room contains some vines. Look for a spot in that room that has more glow than other glowing areas in that room.
OK, had wrong pole in mind.
Re: Tomb of Princes Easy Secrets - EricC - 07-16-2014
Finally found them all. The last one was a bear to find. It really looks like there should nothing there. Nicely done.
Re: Tomb of Princes Easy Secrets - gwmm - 07-19-2014
I've played that mansion like approximately twenty times, and I still haven't found all 13 secrets. Highest I've found is 11.
Re: Tomb of Princes Easy Secrets - Freddy - 11-11-2022
74405756564B320 wrote: Finished it with all secrets and money in just a little bit more than half an hour. ...
Really? Today I did finish this mansion with 61 %.
This is a very clever build mansion with a large variety of puzzles. And because of the missing stuff a return visit worthwhile.
Smile
Question in the margin: is it possible that the playing time stops while using the map?
