About Luris - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: Discussions of approved MM1 and MM1 HD custom mansions (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=11) +--- Forum: Luris (https://actionsoft.com/forum/forumdisplay.php?fid=109) +--- Thread: About Luris (/showthread.php?tid=1097) |
Room 12500 - nancygevans - 04-18-2009 I need help in this room to get the green key. I know it must be in the green tile rectangle but can't figure out how to get inside. Hint please! Thanks for all your hard work, Nancy Re: About Luris - rose - 04-18-2009 Have you tried everything? Jumping, kneeling etc????? Re: About Luris - otg - 04-18-2009 SandyBean wrote: In Room 13302; I must say that I find it quite astonishing that you managed to end up down there alive after pulling the lever in the lower right... I sure can't... It should be impossible to go to the left as you seem to have, the only way I can get jack down there is by jumping down from above, and then he comes down as a skeleton... If you tell me how you did it, I can tell you if it's a JS or not [edit] I managed to reproduce the JS, and it sure is a JS... a strange one though I fixed it, sending an update to the admins[/edit]
Re: Room 12500 - otg - 04-18-2009 nancygevans wrote: can't figure out how to get inside. Hint please! don't just slide, slide with a twist!
Re: About Luris - sherryl199 - 04-20-2009 OK, I need a hint - in 10902 are all 5 keys inside the maze? I've spent wayyyyyy too much time on this room! Great mansion - very hard but not unfair. For me it's the kind to step away from and return in a day or two. Re: About Luris - otg - 04-20-2009 sherryl199 wrote: OK, I need a hint - in 10902 are all 5 keys inside the maze? I've spent wayyyyyy too much time on this room! Great mansion - very hard but not unfair. For me it's the kind to step away from and return in a day or two. Yes they are all there. There's no way back so they have to be. The little maze can be tricky, but not impossible of course
Re: About Luris - SandyBean - 04-20-2009 Really enjoying this Mansion, but unfortunately my Jack has an often detrimental exploration habit. : ![]() He decided to try jumping off to the right at the top of the screen here in rm 12498, and although the fall was wondrous and lengthy, ultimately he did die! Not sure if it is worth fixing or possible? Maybe my Jack is the only suicidal one! ;D OTG: you mentioned your GF, AK was responsible for designing most of the rooms with moving monsters? Well, Jack would like her to know he thinks her Devious and Evil when she created rm. 11698. He has yet to get through that room without losing at least one life! [smiley=evil.gif] Thanks again to both of you, SandyBean [smiley=2vrolijk_08.gif] Re: About Luris - otg - 04-20-2009 SandyBean wrote: Really enjoying this Mansion, but unfortunately my Jack has an often detrimental exploration habit. : Depends, did you mean Jack fell out of the room? I couldn't make him do that, but I could make him fall and die, since the platform is a little too fast, it gets below 6 stones underneath Jack before he lands Well, Jack would like her to know he thinks her Devious and Evil when she created rm. 11698. He has yet to get through that room without losing at least one life! [smiley=evil.gif] I'm afraid I'm responsible for that one... but the one you attached is hers, with the moneybag that moves around by itself... that's her trademark [stuff and enemies moving around in perpetual motion] [even if I used it in some rooms] Thanx for the fine words
Re: About Luris - SandyBean - 04-20-2009 Hi OTG, My Apologies.... it was a few days ago we played that spot (repeatedly, most likely due to the Devious and Evildesigning by YourSelf [smiley=evil.gif] in certain rooms!) and I mislead you by saying Jack jumped to the right. I replayed it just now, and he has to walk off at the uppermost right tile, and will fall a wondrous, glorious, albeit painful death. Hope that helps. ![]() Also would like to say I am Most Impressed with AK's concepts of the perpetual moving monsters and money, very well done! [smiley=tekst-toppie.gif] Thanks, SandyBean [smiley=2vrolijk_08.gif] Re: About Luris - josephine - 04-21-2009 SandyBean wrote: ... unfortunately my Jack has an often detrimental exploration habit. Ha! You're funny SandyBean ;D |
