MM2 - Brave New World - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: General Custom Mansions Area (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=4) +--- Forum: Free Uploading and Downloading (https://actionsoft.com/forum/forumdisplay.php?fid=19) +--- Thread: MM2 - Brave New World (/showthread.php?tid=2204) |
Re: MM2 - Brave New World - Freddy - 01-18-2024 0111060F0F630 wrote: Found a possible JS in room 15695, see pic.I knew I needed an amazing betatester! There is an easy way to solve the JS, I think, but what I have in mind doesn't look nice ... In weekend I open the builder to see what I can do. Re: MM2 - Brave New World - Freddy - 01-19-2024 43776061617C050 wrote: [quote author=0111060F0F630 link=1671814205/298#298 date=1705592952]Found a possible JS in room 15695, see pic.I knew I needed an amazing betatester! There is an easy way to solve the JS, I think, but what I have in mind doesn't look nice ... In weekend I open the builder to see what I can do. A neatly fixed Jack-stuck is better than a Jack-stuck! ![]() Early this morning I found a good solution for the issue. Zip 010 is enclosed. Re: MM2 - Brave New World - brell - 01-20-2024 The JS fix is good - and in a way it also helps the player solving the puzzle. Finished with 100% secrets but am missing Ikr 500.Will play through the mansion again later and check all signs. Re: MM2 - Brave New World - Freddy - 01-20-2024 6171666F6F030 wrote: Will play through the mansion again later and check all signs.Maybe just wait a little bit or start in the transitzone. Because I am already busy with changes at the signs in the purple area. The first sign should look like this. I know it is a (too) long text, but I'd like to explain the vision behind my way of building. Re: MM2 - Brave New World - brell - 01-21-2024 Freddy, are you sure that section 1 contains $3575? I have 6 secrets but only $3525 and cannot find any more. Re: MM2 - Brave New World - Freddy - 01-21-2024 I am going to reload BNW 010 to check. Re: MM2 - Brave New World - Freddy - 01-21-2024 Must be my bad. :-[ When I installed the check points I certainly didn't replay the whole mansion. I assume that I checked my 1st save in the room below and forgot that there are two coins between the CP and the save. I'll add this issue to my fix-list. Re: MM2 - Brave New World - brell - 01-22-2024 4050474E4E220 wrote: Freddy, are you sure that section 1 contains $3575? I have 6 secrets but only $3525 and cannot find any more. I just replayed the first section and have 3575 now. Sorry, my bad. Don't understand how I could miss 50. Is it possible that you added 50 or 2x25 somewhere in later versions? Re: MM2 - Brave New World - Freddy - 01-22-2024 In the end the story is rather funny. After reloading BNW 010 I replayed the purple section and missed $ 50 just like you. After your today's post I replayed it again and didn't miss any dollar. Just like you. Crazy! In my case I am pretty sure what happened. There is a 'dirty' gold coin in the flame of a torch (room 16300) that I dare to miss. So now I took care about that spot. Conclusion: the CP was okay! [smiley=happy.gif]
Re: MM2 - Brave New World - brell - 01-26-2024 After replaying: 16899: If you miss the $200 money bag you won’t get a second chance. 17501: I have 14475 but max score is 14550 I have all secrets. The difference is 75 but I missed a $200 money bag 18098: I have all secrets. ! have $19075 but max is 19150. Same difference as in 17501 The problem is in the second section. 17496: I have all secrets. Max gold is 24500 but I have 24225. Difference is now 275. Missing 200 in the grey section 17292: It is possible to trap the head in a place (in the center of the room) where Jack must use a shield or sacrifice one life to get rid of it. 16893: I have all secrets. I have $28875 but the max is $29300. Difference is now 425. Missed 150 in the green section. 16093: Have all secrets and $33750 but max is $34050. Difference is now 300!!!!!????? 15896: I have all secrets. But only $38275 but ssign says max is $38650. Difference is now 375. But: Should Jack first finish 15897 and 16097 before going to the checkpoint? Finished with all secrets and $64325. Should be 64625. Missing 300. |
