Spider palace any version - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 130 (https://actionsoft.com/forum/forumdisplay.php?fid=13) +--- Forum: 998 (https://actionsoft.com/forum/forumdisplay.php?fid=165) +--- Thread: Spider palace any version (/showthread.php?tid=1792) |
Re: Spider palace any version - VernJensen - 08-11-2011 5845594F2A0 wrote: Ok, I think I have got it. The first time I tried to open Spider palace or any other original mansion, through the Open Mansion choice, I got folder and when choosing one it open up as folder do and shows the content. Vern had said it was possible to play mansion even if the are zipped. I zipped the Spider Palace Easy. Then I used Open mansion and clicked on SP easy folder but is behaved like the game, not as an folder. I did n't see the zipped file. If I tried to open any other mansion which were not zipped they open as a folder. Rose -- to open a mansion using Open Custom Mansion, select the folder (i.e. Nightmare Mansion) and click the Choose button. This will play it. To ZIP a mansion so that it is playable, you must open up the mansion's folder (i.e. Nightmare Mansion Hard), Select All of the contents (there will be a lot of folders select), and Make Archive on all of them. Then rename the Archive.zip to be the same name as the mansion (i.e. Nightmare Mansion Hard.zip) If you zip only the parent folder, it won't work. |
