The Caves and the Castle - Printable Version
+-- Forum: Discussions of approved MM2 custom mansions (Mac only) (https://actionsoft.com/forum/forumdisplay.php?fid=9)
+--- Forum: The Caves and the Castle (https://actionsoft.com/forum/forumdisplay.php?fid=46)
+--- Thread: The Caves and the Castle (/showthread.php?tid=1459)
Pages: 1 2 3
Re: The Caves and the Castle - brell - 09-06-2010
5C676E7D7F666A0F0 wrote: Ok, I have a new problem. I'm in Room 10679 and I can't go anywhere.
You'll ask how I got here. Well, I discovered I didn't need to use all of the red keys at the beginning. I left one of those unopened. I missed opening the blue door in Room 11278. I couldn't go back and open it. I didn't have a yellow key to be able to retrieve the purple key. I kept going up and then to the right and down. Now that I have a yellow key I can't return to the left or get to the other grey bat platform to go up.
You must mean the blue door in room 11279, which leads to room 11278, right?  If you missed that door, you must have opened the red door in 11279 with your spare red key.
This leads you to room 11079 and since you don't have a blue key you go up to the next room above, which is room 10879.  In that room you MUST get the blue key and go back down to find a red key.  With that red key you open one of the red doors in room 10879.  I just can't see that you are stuck.  You can go to the right and back down to room 10879.  You have a red key and can open the other red door in that room, right?
If my assumptions are not correct, then you must tell me:
1. When you first arrived in room 10879, did you have any key at all, and if you did, which color?
2. Tell me what you did after you arrived in room 10879 until you are in the situation on the picture in room 10679
Take a close look at your map. I am almost sure you are not stuck.
Re: The Caves and the Castle - Sharpie - 09-07-2010
You are correct on the room numbers for the blue key. I'll open it up and look at it, I believe you are correct that I do have somewhere to go. :-[ I need new glasses.
Re: The Caves and the Castle - SandyBean - 12-06-2010
Wow !   Great Mansion, very tricky on Normal, Jack and I are going back (after a wee rest) to try Difficult level !
Thanks so much Brell for making a great and challenging place for my Jack to play in...hope to see a new mansion from you soon !
Take care,
SandyBean  [smiley=2vrolijk_08.gif]
Re: The Caves and the Castle - brell - 12-07-2010
Thanks for the compliment, SandyBean. Yes, TC&TC are supposed to be tricky but not hard. The player can almost always think ahead and ponder how he/she is going to solve the puzzles. Usually there is no rush!
