Beta 4: The caves and the castle - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Beta 4: The caves and the castle (/showthread.php?tid=1372) |
Re: Beta 4: The caves and the castle - brell - 07-27-2010 All remarks about the easy and normal versions have been checked and resolved. Thanks. Re: Beta 4: The caves and the castle - brell - 07-28-2010 51584E585050390 wrote: HARD Done and done Re: Beta 4: The caves and the castle - brell - 07-28-2010 0A0315030B0B620 wrote: HARD Fixed 0A0315030B0B620 wrote: The hidden cave with the key is now clearly hinted. If someonedoes NOT take those coins he/she will NOT be able to move on in the mansion. The room is now silent, so the key-appearing sound should not go unnoticed. Sound is widely used in MM mansions to give hints, so those that play without sound just have to accept the disadvantage. Of course players can turn the music off at all times. 0A0315030B0B620 wrote: I'm sorry but I cannot reproduce this. 0A0315030B0B620 wrote: There is a secret entrance where the coin is, now there are more coins to make it more obvious. Re: Beta 4: The caves and the castle - brell - 07-28-2010 777E687E76761F0 wrote: HARD This is simply NOT true. You have been to the room below. Just check your map and walk off the ledge to the left. 777E687E76761F0 wrote: 10679 - What is the point of the blue bat brick taking Jack to the ledge above the spider? He can't get down without dying! Sorry, my fault, fixed Re: Beta 4: The caves and the castle - brell - 07-28-2010 2E2731272F2F460 wrote: HARD Fixed 2E2731272F2F460 wrote: Again I cannot reproduce this 2E2731272F2F460 wrote: 10279 - Ok, so how does Jack get down without trying to use the pole & have to go thru that nasty disappearing brick thing in the room below so that he can continue. see pic Jack picks up a blue key to use in the room below, so he takes the pole down to that blue door. Regarding the nasty disappearing brick thingin the room below: The player HAS already been in that room so he/she sholud already be aware of the hole, which is very clearly hinted with the bricks on both side. 2E2731272F2F460 wrote: 10280 - This is a SUICIDE ROOM. There definitely should be a save before starting it. I mean, so many trolls, hidden from view.....this is nasty, real nasty!!! There is NOTHING hard about this room. Just WAIT and see ... 2E2731272F2F460 wrote: 10085 - When Jack died by the snake on the main level, he reappeared in the middle of the closed grey door on the left. Yes, but he can still walk, right? Anyway, I don't see how I can fix this. Re: Beta 4: The caves and the castle - brell - 07-28-2010 7B7264727A7A130 wrote: HARD No he doesn't. He uses the blue bat platform to go back. 7B7264727A7A130 wrote: Now, if he does miss it & goes thru the entire left side to the top, to the 1st save in room 10080 & proceeds to the right and finds the missed section exit in room 10284, he can't go down to finish it because the grey doors are closed. It is up to the player whether he/she backtracks or not, OR restarts from an earlier save point. 7B7264727A7A130 wrote: *** NOTE *** But there IS an exit from room 10484 to 10284. I will NOT change anything here. This is just a puzzle. Jack must enter 10482 from 10484, pull a lever to open a door, and then go back and enter 10284 from above. If he misses it he has just missed a few secrets and treasures, which he can the look forward to get in a later retry. Re: Beta 4: The caves and the castle - brell - 07-28-2010 686177616969000 wrote: HARD Yes - if he is very forgetting by nature. When he first arrives in this room both bricks are in the floor so it impossible for him to fall down. If he arrives from another room there are clear hints that something is wrong with the floor between the two solid bricks that rise from the floor on both sides of the bat bricks hole. 686177616969000 wrote: 11284 - THERE IS SOMETHING SO WRONG IN THIS ROOM! Agreed, reduced troll speed. What hidden coins? 686177616969000 wrote: 11084 - This is NOT right. The lava rock hides missing flooring. If Jack moves to the right of the ladder, he falls. Everything is clearly hinted here. The rock to Jack's right is clearly in front of the ledge he is standing on. To the left we have the sount of the disappearing bricks, the coins and the top of the lever. And when Jack has jumped to the lever he is clearly behind the rock. Then he pulls the lever and patiently waits for his ride. 686177616969000 wrote: 10884 - Pls check this room. Jack pulls the lever, but the brick with the snake did not move for me. So the bat brick way under it could not take Jack up to the next room. Works perfectly for me. 686177616969000 wrote: 10484 - Either make an exit to the room above or make it easier for Jack to get off that bat mobiel to back track for the 3rd time. I don't understand. There is an exit to the room above to pull a lever for opening a grey door. The batmobile is the fastest way for Jack to go back. Players that skip this section and decide to backtrack (instead of using a former save point) should only have to backtrack once. Re: Beta 4: The caves and the castle - brell - 07-28-2010 676E786E66660F0 wrote: HARD Yes, they do! Patience is a virtue. 676E786E66660F0 wrote: 10083 - see pic. The fish is right under one of the bricks. This definitely is a cheap death!!!Maybe it was intended this wayWhat moving brick? The lever has nothing to do with this.676E786E66660F0 wrote: 9485 - If Jack is on the ledge above the green door & wants to get down to the floor level, he can't. When he tries to jump onto the disappearing bricks, he ends up on the ledge above him.Yes, he can! Try another approach! 676E786E66660F0 wrote: 9286 - The skeleton gets activated while Jack climbed the ladder to get the key, but he did not have another yellow key to open the 2nd yellow door. Now he will die, as the skeleton is in the way down. not good.You are right - fixed. 676E786E66660F0 wrote: 9285 - I only knew of the green hidden key because I saw it in the MLB. But my Jack still missed it by the way he was jumping. NO ONE WILL KNOW THAT THERE IS A HIDDEN KEY HERE. there should be a clue.The key can be seen rotating behind the statue. I can easily jump for it. 676E786E66660F0 wrote: 9585 -Sorry, but there is no room number 9585, so I don't know which room you are talking about. I'll assume you mean 9685: There is NO Jack-stuck in this room. Jack MUST go up to continue. 676E786E66660F0 wrote: 9886 - this room is so boringly slow. those 2 horizontal moving bricks end up one on top of the other, making getting the money bag impossible.I agree with you and have made some changes. 676E786E66660F0 wrote: 10287 - I think that this is suppose to be the 3rd save point, yet the pop up told me that this already exists and do I want to replace it. I then checked my saves and it only shows 2 of them instead of 3. Pls look into this.I'm not sure what you mean but there should be six saving points in mansion now. 676E786E66660F0 wrote: 10086 - there seems to be some sort of invisible step & wall under the gold coin on the main level. it prevents Jack from going back. if he could have seen it, then he would have made sure he did not have to back track.Yes, Jack can go from right to left but not the other way. He does not have to backtrack anything, just jump ![]() 676E786E66660F0 wrote: 10087 - check the stairs pls. jack can't seem to get thru to p/u the goodies.Then try again! Really! 676E786E66660F0 wrote: 10290 - the scorpion & the one spider, it all happens so fast that jack has to die.No, it doesn't! Try again. Note very closely how they move. Hint: A jump back may be the cure. 676E786E66660F0 wrote: 10089 - personally, i think that the fire lamps should be activated in this room and in the beginning of this section.But then there is not hard anymore, is it? 676E786E66660F0 wrote: 9889 -Jack can easily avoid the trap when coming from below but the spider is too much and has been removed. 676E786E66660F0 wrote: 10090 - scorpions to close together to make a safe jump 1st time around.Fixed 676E786E66660F0 wrote: 10291Yes, if Jack dies, he'll have to jump. Didn't you read the sign, which can clearly be seen behind the pillars? The ladders in this room can also be seen behind the pillars. Jack HAS to open the door to the left to be able to finish the game and can't avoid to get the red key. 676E786E66660F0 wrote: 10292 - perhaps a layer problem? watch where the skeleton dies. it's way before the actual water & the sound of splashing.Yes, I know. I have seen this before in mansions with lava and I don't know how to avoid this. 676E786E66660F0 wrote: 10094 - the sign could includeI'll think about itmaybe it's Shangri-La? ![]() 676E786E66660F0 wrote: How can one back track from the exit to get to a missing room 10491? the bat brick is gone from room 10091One can't 8-) 676E786E66660F0 wrote: And there are now. Thanks a lot for your testing. Re: Beta 4: The caves and the castle - brell - 07-28-2010 Dear Semi-Native and Rob. I have added a few trinkets and a saving point - or two in the hard version. Thanks for your testing. Re: Beta 4: The caves and the castle - Semi-Native - 07-28-2010 Trinkets and Saves are always welcome, especially in the hard version. [smiley=beer.gif] |
