Beta 4 Available - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Beta 4 Available (/showthread.php?tid=1371) |
Re: Beta 4 Available - Semi-Native - 06-27-2010 Sorry rose, I know you're having a problem with your code. I meant after you get it working, then you'll see the Open Mansion option for the custom mansions. Re: Beta 4 Available - cwncwn - 07-03-2010 Having tested the paypal. All appeared to work well, but my activation code no longer works. Got a new code and that does not work as well. Says I used invalid codes. Went to next script and it said that the registration code could not be found. Now i cannot access beta 4 ............cw >
Re: Beta 4 Available - Semi-Native - 07-03-2010 cw, did you also enter your name exactly the way you registered? Unfortunately, this is something Vern will have to fix, and he's gone for most of the month! Hope you get it working.
Re: Beta 4 Available - margherita64 - 07-03-2010 Now I'm having problem too!! My MM beta4 works fine till this morning and now asked me the registration code again, I filled the form and I had the message below... so I can't test anymore
Re: Beta 4 Available - Semi-Native - 07-03-2010 Aaaagghhhh!!!! This is not good! ![]() Re: Beta 4 Available - Wingy - 07-04-2010 Did you make sure you were connected to the internets when you typed it in? Or perhaps you mistyped it? Or maybe you'll have to wait till Vern gets back on the 15th, or open the mansions you want to test with a previous version of the beta. Re: Beta 4 Available - margherita64 - 07-04-2010 46787F7668110 wrote: Did you make sure you were connected to the internets when you typed it in? Or perhaps you mistyped it? Or maybe you'll have to wait till Vern gets back on the 15th, or open the mansions you want to test with a previous version of the beta. Yes, I were connected... no, there was not mistype... I inserted the code a week ago and the application works without problem. Now ask me the code again and doesen't accept it. Is it ok if I use beta3? Re: Beta 4 Available - triforceguy1 - 07-04-2010 Is it all right if I let margherita use my code (or can the MM2 codes only be used with just one computer this time round)? Re: Beta 4 Available - Semi-Native - 07-04-2010 I think it would be okay to try that. Give it a shot, and thanks. Re: Beta 4 Available - margherita64 - 07-04-2010 Thank you Leon! ![]() If you would to send me your registration code you can contact me at fra.albano@katamail.com |
