Mansion Comments: Jasperlone Mountains - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Mansion Comments: Jasperlone Mountains (/showthread.php?tid=1312) |
Re: Mansion Comments: Jasperlone Mountains - hawaii - 04-08-2010 7B45424B552C0 wrote: Yes, I'm aware of this issue, and it shall be fixed -- what I will do is the yellow door will be first with a blue door behind it, instead of blue then yellow, so you must get the yellow key first by completing the section. Putting the yellow door 1st, then the blue door is still not a solution, as I had a yellow & blue key in my saddle bag. That is why I went thru those doors, so reversing their order won't make the right choice either. Perhaps a sign indicating the door on the left 1st? I found the red keys no problem. I will wait for the amended version. Great Mansion! Re: Mansion Comments: Jasperlone Mountains - Wingy - 04-08-2010 Yes, you could very well have a yellow key if you did the other half of the mansion first. However, if you skip the area that with the single blue door, and use up the extra yellow key you found instead, two things will happen: • You won't get the best possible number of money in the mansion. • You won't get the best possible number of secrets in the mansion. At the end, (in the next version, beta2) that yellow key can be mighty handy for a bonus at the end.
Re: Mansion Comments: Jasperlone Mountains - VernJensen - 04-08-2010 Regarding room 14910, where you can get stuck on the roof... Do you think I should modify the game to allow Jack to jump up into the room above, when he's on bricks near the top of a room? Or would this cause problems in existing sequel mansions? Re: Mansion Comments: Jasperlone Mountains - Wingy - 04-08-2010 Don't worry Vern, I've figured out a way to avoid this problem, by adding a secret there, which you can use as a passage to get back down, one way though. I think you better keep things the same, seeing this may conflict in mansions. I have some rooms in Castle Basano I remember which this could cause problems... Re: Mansion Comments: Jasperlone Mountains - hawaii - 04-11-2010 14300 Medium 3rd lever on the lower left. I can hear it open something, but where is it? It sounds like a grey panel door, but I can't find it? Re: Mansion Comments: Jasperlone Mountains - Wingy - 04-12-2010 :
