Mansion Comments: Citadel of Dr Cassiopus - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Mansion Comments: Citadel of Dr Cassiopus (/showthread.php?tid=1310) |
Re: Mansion Comments: Citadel of Dr Cassiopus - hawaii - 04-06-2010 7C716E797C76797479180 wrote: Citadel of Dr Cassiopus Easy, rooms 15113 and 15114 Great Catch Mapman! ![]() My Jack did loose his life but when he re-appeared all went well. So I would never have found that problem. Easy Mode - Citadel of Dr Cassiopus - hawaii - 04-06-2010 Great Roof Top Secret Area...Manifesting out of No Where! I know that the sign says that there is only a one time help, but the grey brick that brings Jack close to the vines is still to close to the edge of the roof. When Jack jumps off the grey brick, he ends back up on the roof with no more help. lolololol No one will know that Jack has to literally fall towards the vines to avoid ending up back on the roof. In the 2nd pic.....Jack has to die to get out of there and reappear on the right side to leave the room and bring back the moving brick. Jack ended up finding these to spots as he was on a mission to find the last red key. We can't find it. We searched the entire map.....what are we missing??? I can't finish the mansion without it. Help Pls. I don't have this mansion in Mansion Level Builder to help me with my search! hmmmmm :'( Re: Mansion Comments: Citadel of Dr Cassiopus - divadnala - 04-06-2010 Hi Missy, The six red keys are in rooms 15312, 15511, 16113 (2 keys), 16311 and 16714 - first 3 pictures below and 2 more in the next post (you can only put a maximum of three attachments in each message). The pictures are taken from the Level Builder so they show detail that won't necessarily be obvious when you're playing the mansion. When you've got through those six red doors there are another six red keys to find before you finish the mansion! Have fun!! Re: Mansion Comments: Citadel of Dr Cassiopus - divadnala - 04-06-2010 Here are the others Missy: Re: Mansion Comments: Citadel of Dr Cassiopus - divadnala - 04-06-2010 Missy - I've had another look at where the red keys are. The one that you might have missed is in room 15511. You have to make that floating ghoul head destroy itself in the flame of the lamp before the key appears. Hard Mode - Citadel of Dr Cassiopus - hawaii - 04-07-2010 Hard Mode: 1st pic, look for Jack in the top left corner, near the skull & room number. Jack can go left into the next room see 2nd pic. Maybe you should block that area off. Jack died doing that. 3rd pic....the last brick is false and Jack falls to his death. Perhaps it should be solid as it seem like a Cheap Death to me. Re: Mansion Comments: Citadel of Dr Cassiopus - hawaii - 04-07-2010 2A27382F2A202F222F4E0 wrote: Missy - I've had another look at where the red keys are. The one that you might have missed is in room 15511. You have to make that floating ghoul head destroy itself in the flame of the lamp before the key appears. Awwww, Thank You sooooo much Mapman, you are a Sweet Heart! Yes, I found all those visible ones....I got so fed up looking for the final key so I closed the mansion. I will have to start over from the last save as I can't find the mansions in Mansion Level Builder. Is room 15511 the 2nd pic you posted below??? I was in that section over and over wondering what the purpose was of that floating head. lolololol I tried all sorts of stuff but not burning his head. lolololol Vern just sent me an email giving instructions to find the mansions in MLB.....I just played the test room & found the key......Sneaky, real Sneaky..... ![]() THANK YOU SO MUCH MAPMAN & VERN! Hard Mode: Citadel of Dr Cassiopus - hawaii - 04-07-2010 Hard Mode Room 16110 Jack fell from the above room, far right bottom level onto the grey doors in the pic below. Hard Mode: Citadel of Dr Cassiopus - hawaii - 04-07-2010 Hard Mode Room 16113 Jack Stuck If Jack misses pulling the lever on the lower level because he jumped on the grey bat brick, he is forced to finish the upper levels to get all the yellow keys. After he opens the yellow doors and goes down on the green bricks, Jack goes over the zappers to get to the lever, yet he makes the same darn mistake and jumps onto the grey bat bricks which bring him up again.....now the green bricks beyond the yellow doors are not available anymore. To make a long story short, the grey bad bricks should let Jack go back down to the lever level. Hard Mode: Citadel of Dr Cassiopus - hawaii - 04-07-2010 Hard Mode: Room 15113 Jack Stuck. Jack rode around the grey bat brick to the spiders & back. He went to jump to pull the lever, fell, died & ended up on the little green disappearing brick, but the grey bat brick disappeared, no where to be found. Jack is stuck. |
