MM2 - Brave New World - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: General Custom Mansions Area (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=4) +--- Forum: Free Uploading and Downloading (https://actionsoft.com/forum/forumdisplay.php?fid=19) +--- Thread: MM2 - Brave New World (/showthread.php?tid=2204) |
Re: MM2 - Brave New World - Freddy - 07-03-2023 48584F46462A0 wrote: [quote author=0C382F2E2E334A0 link=1671814205/198#198 date=1688206549]... 18099 ...It is very vague but ok I did find an other shade of brown for a little bit more contrast. It will be seen in the next zip when the grey area is (more or less) ready. Re: MM2 - Brave New World - Freddy - 07-08-2023 Sorry for the delay! To gain as much time as possible, first of all, here is zip 025. A few words are coming later. Re: MM2 - Brave New World - Freddy - 07-08-2023 Your best save 9 in room 18099 gave $ 21.500 with 20 secrets found. The next save-stop is in room 17497. Best result there is € 25.000 in an unfinished room. As far as I know the concept of the new grey area is new. Do not copy this idea because it is far too much work! ;D ![]() To avoid spoiling any kind of playing fun I prefer to tell you nothing in advance. :-X Between the lines I did understand that you take MMF with you? So I may disturb you with a lot of small talk with pics etc? That would be 8-) Re: MM2 - Brave New World - brell - 07-09-2023 Jack lost his ride, see pic. Now what? Room 174977: Jack has the yellow key but cannot open the yellow door. There is also an unrechable blue key in another room, which does not seem to be needed. Re: MM2 - Brave New World - Freddy - 07-09-2023 5545525B5B370 wrote: Jack lost his ride, see pic. Now what? Once the 'flying carpet' got activated it is still activated in the room where it started. There is a way back to that spot. And I reduced the speed to 7 (originally 20!) to make the jump on the flying carpet rather normal. 5545525B5B370 wrote: Room 174977: Jack has the yellow key but cannot open the yellow door. Do you mean that the yellow key doesn't open the yellow door? :o Or that Jack didn't find the way to that door? 5545525B5B370 wrote: There is also an unrechable blue key in another room, which does not seem to be needed. All keys are needed. At the new save point Jack shouldn't have spare keys. Re: MM2 - Brave New World - brell - 07-09-2023 6D594E4F4F522B0 wrote: [quote author=5545525B5B370 link=1671814205/203#203 date=1688891156]Jack lost his ride, see pic. Now what? Once the 'flying carpet' got activated it is still activated in the room where it started. There is a way back to that spot. And I reduced the speed to 7 (originally 20!) to make the jump on the flying carpet rather normal. Of course, I see it now ![]() 6D594E4F4F522B0 wrote: [quote author=5545525B5B370 link=1671814205/203#203 date=1688891156]Room 174977: Jack has the yellow key but cannot open the yellow door. Do you mean that the yellow key doesn't open the yellow door? :o Or that Jack didn't find the way to that door? The yellow key does not open the yellow door. It is easy to get the key via armlifting but it never opened the door. 6D594E4F4F522B0 wrote: [quote author=5545525B5B370 link=1671814205/203#203 date=1688891156]There is also an unrechable blue key in another room, which does not seem to be needed. All keys are needed. At the new save point Jack shouldn't have spare keys. Well, I could not get that key and the blue door opened by a T trigger. Re: MM2 - Brave New World - Freddy - 07-09-2023 The flying carpet was a difficult design issue. That was one of the things that took a long time to get it work. Anywhere Jack may fall or jump from the carpet, there had to be a descent solution. Even when he died! I needed to be sure that he always reappears at a save spot that is no Jack-stuck. It never occurred to me that Jack lost his ride at the spot you showed on the image (easy to fix), but something similar happened at the top of the most right shaft. That is why the right shaft is wider than the left one, where Jack goes up and doesn't have that problem. Re: MM2 - Brave New World - brell - 07-09-2023 74405756564B320 wrote: No need to fix IMO as Jack can always find his way down again. I tried again and noticed that the blue key becomes available. Missed that last time. However, when Jack jumps off the moving platform in that room, he must be careful not to jump too far as then he will die in the room to the right. I see that you are using ideas from Whiskey bar ![]() Re: MM2 - Brave New World - Freddy - 07-09-2023 The yellow doors (plural). Misunderstanding. You were not talking about the first yellow door in the room where the flying carpet started, but about the other one. It is important that you reported the blue key-door issue! :exclamation I didn't realize that the blue door could be opened with push-ups (easy to fix). It was supposed to be a surprise: when Jack picks up the blue key at the very same time the blue door opened. That is the first weird coloured door. Do this: return to the room with the blue door and collect ALL the money. Re: MM2 - Brave New World - Freddy - 07-09-2023 Posts crossed each other. Got to the save point? |
