Help Lara - Printable Version
+--- Forum: Pirate Invasion, The (https://actionsoft.com/forum/forumdisplay.php?fid=134)
+--- Thread: Help Lara (/showthread.php?tid=583)
Re: Help Lara - brell - 12-25-2008
Nancygevans, can you give a description of that room? I don't have a copy of MM or the mansions, so I need more info to be (hopefully) able to help you.
Help Nancy - nancygevans - 12-25-2008
It is the blue tiled room 2 levels directly above the end of the ladder maze, with a save pedestal. I haven't been able to access the bottom level and go left, which is where a lot of the rooms I haven't been to are. Maybe the access is from the other side of the hidden rooms, earlier in the game? If so, can you tell me where to get in?
Thanks, Nancy
Hi Nancygevans. Yes, you have to use another entrance to those
hidden
rooms. From where you are now it is propably best to find your way to the aft of ship and from there go back to the fore. The way to the
hidden
rooms is through my cabin, but you have to have a certain key with you.
Two notices:
1. When I was building the ship I wanted to have a quick entrance to the
hidden
rooms from the room you are in now, but Freddy, my main beta tester of this mansion, talked me out of it.
2. When I first released TPI the way from the aft back to the bridge area was not included, but I got so many complaints that I decided to change that.
Perhaps, when I can, I will change this back: a) open the way from the blue room that Nancegevans is in to he
hidden
rooms and b) close again the way from the aft to the bridge since it wnðt be needed any more.
Re: Help Lara - nancygevans - 12-25-2008
Thanks Brell and Merry Christmas! I'll give it a try.
Help Nancy - nancygevans - 12-27-2008
OK I found the way into the hidden rooms but I am lacking the purple key I need there. I figured out it's the one in the right side of the mirrored rooms, but I can't get to it. Please give me a hint how to access the right side of the mirrored rooms.
Thanks, great mansion!
Nancy
Re: Help Lara - Jackie - 12-27-2008
Nancy,
In an earlier post in this thread Brell says:
1. You cannot go to the right part of 31296.
You need to find the purple key on the left mirror side. Undecided
Re: Help Lara - nancygevans - 12-27-2008
Thanks! I guess I'm barking up the wrong tree. But I am one purple key short when I go to the hidden rooms. Maybe I'm using them in the wrong order.
P.S. I did find the left purple key.
