A "manual" for beta testers - Printable Version
+--- Forum: Custom Mansions / Designing (https://actionsoft.com/forum/forumdisplay.php?fid=21)
+--- Thread: A "manual" for beta testers (/showthread.php?tid=534)
Re: A "manual" for beta testers - hawaii - 11-25-2012
4D504C5A3F0 wrote: Do you mean the cheating commands? Weren't they in a Read me file comming with the MM?
Hi Rose,
Yes they were in MM1 normal, but I don't have that version anymore. I only have the MM2 HD and it did not come with anything but the game. No Mansion Level Builder, Read Me, Custom Mansions (I had to download that separately).
So where would I find the list of cheat commands? Also, my notification is not sending me emails. Hmm? I only found your reply bcos I was in my notification folder trying to figure out why I am not getting notification emails. Any suggestions. I have been away for so long that I have forgotten so many things.
Re: A "manual" for beta testers - RobSeegel - 11-25-2012
If you no longer have the original game, then you will not be able to use the builder that you downloaded separately. I found my file, and I will email it to you.
Re: A "manual" for beta testers - brell - 11-25-2012
Missy, to avoid confusion, you and others should refer to the HD version as MM1 HD. There are now 2 versions of MM1:
The original with mansion builder. An example of an included mansion is
Cathedral towers
. An example of a custom mansion is
Midnight mazes and monsters
. Not playable in Lion or Mountain Lion.
The HD without mansion builder. A HD version of the original game. It has the same included mansions as the original MM1 above plus two more. Most but not all of the custom mansions that were designed for the original run in it after a conversion to the HD format. Playable in most versions of OS X and Windows
Then there is MM2, which you, among many others, tested. It comes with mansion builder and is not playable in Lion or Mountain Lion. That is the sequel to the original with new monsters (trolls etc.), platforms that go between rooms etc. An example of an included mansion is
Dr. Demented's Den
A fine mess
The
cheating
commands you are talking about are the
command-D
combination.
