MM HD The Dragon's Trap (Hard): floating lever doesn't function - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: Discussions of approved MM1 and MM1 HD custom mansions (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=11) +--- Forum: Dragon's Trap, The / hard (https://actionsoft.com/forum/forumdisplay.php?fid=92) +--- Thread: MM HD The Dragon's Trap (Hard): floating lever doesn't function (/showthread.php?tid=1938) Pages:
1
Re: MM HD The Dragon's Trap (Hard): floating lever doesn't function - m1ck - 11-17-2011 Sheesh I'm sorry I even asked. Re: MM HD The Dragon's Trap (Hard): floating lever doesn't function - rose - 11-17-2011 Ok, I am sorry! I did check the left part but forgot to do it from the right side. Sorry again! Re: MM HD The Dragon's Trap (Hard): floating lever doesn't function - brell - 11-17-2011 No harm done, Rose. Mick, don't be sorry. No Jacks were harmed 8-) Re: MM HD The Dragon's Trap (Hard): floating lever doesn't function - josephine - 11-18-2011 Hi all- I remember playing DTH in MM1 and having the floatinggreen lever. Sorry, I don't recall how or what happened but I did eventually finish the mansion. Strangeness :-? Re: MM HD The Dragon's Trap (Hard): floating lever doesn't function - brell - 11-18-2011 It is all very simple. If Jack pulls a blue lever in this room the green lever will become unuseable until he re-enters the room. If Jack enters this room from the room above via the LEFT ladder the green lever will be available. Jack can also enter the room from the room to the left at the bottom ledge and the green lever will be available. Re: MM HD The Dragon's Trap (Hard): floating lever doesn't function - RobSeegel - 11-19-2011 2D3D2A23234F0 wrote: It is all very simple. I remember this room now. The idea is that there were two pathways that crossed the others path. No one was intended to pull both a green AND a blue lever. Just one blue lever OR one green one, depending on how Jack arrived to the room. I think it was simply a clever flourish on toybox's part. Re: MM HD The Dragon's Trap (Hard): floating lever doesn't function - brell - 11-19-2011 Exactly! As I put it myself: ...Jack cannot pull both blue and green levers on the same ride through this room. That is a part of the beauty of Toybox's design. Re: MM HD The Dragon's Trap (Hard): floating lever doesn't function - m1ck - 12-04-2011 Yes. Lever order counted big time in this. |
