Spider palace any version - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 130 (https://actionsoft.com/forum/forumdisplay.php?fid=13) +--- Forum: 998 (https://actionsoft.com/forum/forumdisplay.php?fid=165) +--- Thread: Spider palace any version (/showthread.php?tid=1792) |
Re: Spider palace any version - rose - 07-31-2011 When hitting choose on a folder it will open up and so it did! Also I haven't unzip anything but the game itself. Re: Spider palace any version - brell - 07-31-2011 Hmm... this is strange. By opening Spider Palace as a custom mansion the saves still work. Then why don't they work when we open a real custom mansion? Re: Spider palace any version - RobSeegel - 07-31-2011 5545525B5B370 wrote: Hmm... this is strange. By opening Spider Palace as a custom mansion the saves still work. Then why don't they work when we open a real custom mansion?I was wondering the same thing. I remembered your comment from the other day and immediately went down and tried to save, and it worked as it was supposed to. What I haven't tried to do is load the saved game. Re: Spider palace any version - RobSeegel - 07-31-2011 4E534F593C0 wrote:That's fine. Vern says that the game should be able to load the mansion directory, or a zip file containing the directory. I haven't tried it yet. Re: Spider palace any version - rose - 07-31-2011 I tried but it was on the MidnightMansionHDBeta4.zip and that might not be right. Re: Spider palace any version - brell - 07-31-2011 665B56675151535158340 wrote: [quote author=5545525B5B370 link=1311668593/11#11 date=1312123313]Hmm... this is strange. By opening Spider Palace as a custom mansion the saves still work. Then why don't they work when we open a real custom mansion?I was wondering the same thing. I remembered your comment from the other day and immediately went down and tried to save, and it worked as it was supposed to. What I haven't tried to do is load the saved game. It is possible to save the games while playing the custom mansions but it is not possible to open the saves since the game cannot locate the Midnight Mansion HD Custom Mansionsfolder from the save folder. On the other hand the game can locate the mansion from the save folder if it is in the /Game data/Mansions folder even if it is played as a custom mansion. Re: Spider palace any version - brell - 07-31-2011 Hehe. I made small CM, put it in the /Game data/Mansions folder, opened the mansion and saved it. Then I tried to open the save. It didn't work. Smart game. It clearly knowsthat the CM was not a built-in
Re: Spider palace any version - rose - 08-01-2011 Ok, I think I have got it. The first time I tried to open Spider palace or any other original mansion, through the Open Mansion choice, I got folder and when choosing one it open up as folder do and shows the content. Vern had said it was possible to play mansion even if the are zipped. I zipped the Spider Palace Easy. Then I used Open mansion and clicked on SP easy folder but is behaved like the game, not as an folder. I did n't see the zipped file. If I tried to open any other mansion which were not zipped they open as a folder. Re: Spider palace any version - VernJensen - 08-11-2011 4252454C4C200 wrote: Hmm... this is strange. By opening Spider Palace as a custom mansion the saves still work. Then why don't they work when we open a real custom mansion? Because the game looks for custom mansions in *two* places, just in case you opened a built-in mansion using the Open Custom Mansion feature. And yes, the place it looked for custom mansions was broken in beta 5. Fixed in beta 6. Re: Spider palace any version - VernJensen - 08-11-2011 Rose and everyone else: to test Spider Palace, simply play all other mansions briefly and enter i winas the cheat code. As long as I left testing cheatsenabled in beta 5 (don't remember if I did) then this will instantly beat the mansion and mark it with a red circle on the map. You can quickly do this for all mansions, allowing you to then play Spider Palace. |
