Dr. Demented's Den Hard - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: Midnight Mansion 2: The Haunted Hills (Mac only) (https://actionsoft.com/forum/forumdisplay.php?fid=3) +--- Forum: Included Mansions (https://actionsoft.com/forum/forumdisplay.php?fid=15) +--- Thread: Dr. Demented's Den Hard (/showthread.php?tid=1633) Pages:
1
Re: Dr. Demented's Den Hard - RobSeegel - 01-07-2011 2030272E2E420 wrote: Of course you have to make the fix for now but in the long run we need a general solution. Wait a sec... I just realized. Are you suggesting that a quirk of the game is actually a bug and should be fixed?! Who are you and what you have done with the real Brell?!
Re: Dr. Demented's Den Hard - brell - 01-07-2011 Hehe. This issue is quite different from ladderjumps etc., which are actually (unintended) features and not quirks. 8-) We could also discuss the difference between quirks and bugs.
Re: Dr. Demented's Den Hard - suztours - 02-11-2011 Okay - I FINALLY finished this mansion... started, stopped, started over, stopped... etc. etc. EXCEPT - there are 2 yellow keys I could not get - couldn't figure out the puzzle to get them. So, I finished but without at least two rooms towards the end. :'( Some HELP on how to get those two yellow keys (one is floating above the lava and one is hanging way up in the top of a room) would be GREAT! suzanne Re: Dr. Demented's Den Hard - rose - 02-11-2011 Suztour - can you supply the room numbers? Cmd + d when you play will let the app show the rom numbers. Re: Dr. Demented's Den Hard - suztours - 02-11-2011 Hey Rose - yes, I know, but I didn't note the room numbers... and it'll probably be a while before I go back to that particular mansion! Re: Dr. Demented's Den Hard - RobSeegel - 02-11-2011 Suztours, let me know if the following info isn't enough. I'll send you a PM with more details later if it isn't. The answer lies in using moving platforms that are located in rooms that are 1-3 rooms away from the keys's locations. In both cases, the platforms take a direct path to the keys and also in both cases, the platforms need to be triggered to be seen (though that's the case for the majority of the platforms in this mansion.). In one case, the answer lies in collecting a number of gold coins to trigger the platform. In another case, the platform is activated by walking over one of the panel triggers. Hope this helps |
