Jasperlone Mts. Hard - Jack Stuck? - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: Midnight Mansion 2: The Haunted Hills (Mac only) (https://actionsoft.com/forum/forumdisplay.php?fid=3) +--- Forum: Included Mansions (https://actionsoft.com/forum/forumdisplay.php?fid=15) +--- Thread: Jasperlone Mts. Hard - Jack Stuck? (/showthread.php?tid=1541) |
Re: Jasperlone Mts. Hard - Jack Stuck? - josephine - 10-21-2010 Any word on this fix yet? I've played through all of MM2 at every difficulty so no more Jack until we get past hereĀ
Re: Jasperlone Mts. Hard - Jack Stuck? - Semi-Native - 10-21-2010 I don't know when the update will come out, but in the meantime, if you just want to play the mansion, you can move it into the Custom Mansions folder and fix the Jack Stuck in the level builder. That's what I did, I put a floor tile to the left of that gray door that will open it. At least that allows you to play. Good practice for the real thing. 8-) Re: Jasperlone Mts. Hard - Jack Stuck? - miltrump - 10-25-2010 The update didn't fix it. Re: Jasperlone Mts. Hard - Jack Stuck? - josephine - 10-25-2010 Same here- Jack is still stuck behind that last grey door. I tried playing forward from my old saved game and also replayed the whole mansion from the beginning, with the same result. Re: Jasperlone Mts. Hard - Jack Stuck? - brdaykin - 10-25-2010 Same experience... double-checked to make sure I was playing the updated version but still no budge. Arr {mild frustration }
Re: Jasperlone Mts. Hard - Jack Stuck? - Wingy - 10-25-2010 If you simply resumed your game from a suspension, then the trigger has already been triggered sadly enough -- You'd have to go back to a previous save point. I just double checked and the trigger to open the far-left grey door works fine in room 14897 from the version I sent in to Vern. If you want to take a look, check and see in the door in the room in the editor matches the trigger's ID. Re: Jasperlone Mts. Hard - Jack Stuck? - brdaykin - 10-25-2010 Anthony, I may very well be getting something wrong, but I didn't resume from a suspended game... I copied the new version to my applications folder and started my saved game from... Jasper Hard 9, Room 15093 (? may have that number wrong). Do you mean I need to re-start the entire mansion? Or just that I have to start from an earlier save point, like 8 or 7? Re: Jasperlone Mts. Hard - Jack Stuck? - brdaykin - 10-25-2010 Sorry to pester! Me again... Screen shot is attached. OR, another option... is the trigger in that room and I have to go back to that section to activate and then run through from there? I should probably just try that instead of asking, but I wanted to make sure we were talking about the same door. The far left isn't the one I can't get through... it's the 2nd from left. Thanks! STill loving it... feeling a little obsessive about finishing, maybe
Re: Jasperlone Mts. Hard - Jack Stuck? - MTGA - 10-26-2010 also opened up the game in the latest version (1.0.2), re-started from a saved game and got stuck here again as well. Re: Jasperlone Mts. Hard - Jack Stuck? - Winters - 10-27-2010 I'm stuck in the same room, #14897, starting from the left side and the gray door won't open. I did not start from a saved game from the previous version. I started Jasperlone Mts. Hard with v 1.0.2.
