The Caves and the Castle - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: Discussions of approved MM2 custom mansions (Mac only) (https://actionsoft.com/forum/forumdisplay.php?fid=9) +--- Forum: The Caves and the Castle (https://actionsoft.com/forum/forumdisplay.php?fid=46) +--- Thread: The Caves and the Castle (/showthread.php?tid=1459) |
Re: The Caves and the Castle - Sharpie - 09-04-2010 I ended up aborting since I never could get past the wall. Re: The Caves and the Castle - brell - 09-04-2010 Catwoman, how did you manage to get up there without a red key? I will release an update to prevent this but I am curious. Re: The Caves and the Castle - Sharpie - 09-04-2010 For me it was quite easy. I had the yellow so opened the door in the room below and then rode up. Glad to hear I wasn't just losing it. (That would be a discussion for a different topic. : )
Re: The Caves and the Castle - brell - 09-04-2010 Yes, but you cannot open the yellow door without getting a red key at the same time. Re: The Caves and the Castle - Sharpie - 09-04-2010 I had retrieved the red key earlier and used it in the room to the left of where I got stuck. Re: The Caves and the Castle - brell - 09-04-2010 So you never got the red key in the room below the yellow door? Re: The Caves and the Castle - Sharpie - 09-04-2010 No I had not. I learned that was my mistake. Re: The Caves and the Castle - brell - 09-04-2010 OK. In the next update you will be able to undoyour mistake.
Re: The Caves and the Castle - brell - 09-04-2010 [movedhere] MM2 Talk [move by] brell. Re: The Caves and the Castle - Sharpie - 09-06-2010 Ok, I have a new problem. I'm in Room 10679 and I can't go anywhere. You'll ask how I got here. Well, I discovered I didn't need to use all of the red keys at the beginning. I left one of those unopened. I missed opening the blue door in Room 11278. I couldn't go back and open it. I didn't have a yellow key to be able to retrieve the purple key. I kept going up and then to the right and down. Now that I have a yellow key I can't return to the left or get to the other grey bat platform to go up. |
