Beta 2: The caves and the castle - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Beta 2: The caves and the castle (/showthread.php?tid=1331) |
Re: Beta 2: The caves and the castle - brell - 04-20-2010 313C2334313B343934550 wrote: Easy Thanks you for your kind words
Re: Beta 2: The caves and the castle - Semi-Native - 04-21-2010 NORMAL 10479 Bat platforms are hidden in the floor. When Jack steps on one while walking, he'll probably fall to his death. Re: Beta 2: The caves and the castle - brell - 04-22-2010 7C4A424602614E5B46594A2F0 wrote: NORMAL Yes, but Jack has many hints of those platforms: 1. He has been in the room below. 2. The small bricks on each side of the platforms to warn and remind him of the danger. Re: Beta 2: The caves and the castle - Semi-Native - 04-22-2010 0313040D0D610 wrote: [quote author=7C4A424602614E5B46594A2F0 link=1271354252/11#11 date=1271880292]NORMAL Yes, but Jack has many hints of those platforms: 1. He has been in the room below. 2. The small bricks on each side of the platforms to warn and remind him of the danger. Yes, but my Jack is forgetful... and clumsy. ![]() Re: Beta 2: The caves and the castle - Semi-Native - 04-23-2010 HARD brell, were you in a sadistic mood when you designed the hard version? I gave up. Well, I was going to try to make it to the end, but then the game froze and I had to force quit. It was a looooonnnngggg way back to the one and only Save I had reached, so I'm dropping it, at least for now. It would be easier to list the rooms I thought were not too hard rather than the other way around. I think you should go through it room by room, make some jumps easier, slow the critters down and eliminate some, and so on. You want people to play your mansion, but as it is, I think most will give up. Don't get me wrong, I love a good challenge, but this one wasn't fun for me. Sorry. :'(Re: Beta 2: The caves and the castle - brell - 04-24-2010 Semi-Native, I'm sorry if you find the hard version too hard. I have removed one spider, that was perhaps too much for Jack to avoid. Maybe I should add a little gold to grant an extra life or add a saving point or two? Please note that everything is NOT as it meets the eye: 1. In room 12079, you should not need to take the upper and much harder route back - unless Jack loses his blue bat platform, which can only happen if he steps off it or gets himself killed while riding it on the way back. 2. A jump is not always needed between bricks in room 12281. Re: Beta 2: The caves and the castle - Semi-Native - 04-24-2010 More gold and more save points would definitely be appreciated.
Re: Beta 2: The caves and the castle - brell - 04-24-2010 I will think about it and decide before second release from now. Vern will release the 3. update this weekend and I want more time before I make such changes to the hard version. Re: Beta 2: The caves and the castle - margherita64 - 04-27-2010 NORMAL - Room 11678 Jack dies and reappered at the point you'll see in the picture: there was no more platform so he can't go back... :o Re: Beta 2: The caves and the castle - hawaii - 04-27-2010 7666717878140 wrote: [quote author=727F60777278777A77160 link=1271354252/6#6 date=1271770639]Easy Yes, he can - in BOTH instances! Just let Jack take a few armlifts! This feature has been known for quite a time now. What is an Arm Lift Featureand how does one do it? |
