Mansion Comments: Mount Peril - Printable Version
+--- Thread: Mansion Comments: Mount Peril (/showthread.php?tid=1315)
Pages: 1 2 3
Re: Mansion Comments: Mount Peril - Semi-Native - 04-07-2010
Oh yeah, I forgot you could get the little trolls to leave the room. Thanks!
Re: Mansion Comments: Mount Peril - hawaii - 04-08-2010
Hi Semi-Native, how do you make those small screen shots without the rest of the desk top showing?
I read that you took them in the editor, but still, no desk top is showing & they are smaller than the ones I take with control, command, 3.
Re: Mansion Comments: Mount Peril - Semi-Native - 04-08-2010
If you use SHIFT + COMMAND + 4, you can select the area of the screen that you want, instead of the whole screen.
4D7B737733507F6A77687B1E0 wrote: If you use SHIFT + COMMAND + 4, you can select the area of the screen that you want, instead of the whole screen.
Smile You are always willing to share & teach.  Smile
I am sure other MM players can make use of these tips as well. Thank you.
I did the above, but now I get an entire border.  But, when I post it here, it disappears.
So how would I get rid of the whole border if I were to send the pic thru regular email attachment?
Sorry, I didn't give the complete explanation. When you use the shift-command-4 keys, notice the little cross-hairs cursor. Use that to click and drag around your selection. Once you let up off the mouse, your picture is taken.
Re: Mansion Comments: Mount Peril - TrixieB - 04-10-2010
Jack Stuck Rm 16901 Normal
I went down all of the conveyor belts to pick the key up at the bottom right. Because the belt is moving to the right I cannot get back up. there is no way to die and suspend/resume puts Jack back at the bottom right. Undecided
Sorry, I forgot to attach the screen shot of 16901 Jack Stuck!
Re: Mansion Comments: Mount Peril - Wingy - 04-10-2010
Yep, I've got that bug sorted out, so it actually looks the same, but you can't duck under.  :Smile Thanks, TrixieB.
Re: Mansion Comments: Mount Peril - hawaii - 04-11-2010
16301 - Normal
Jack Stuck, see pic.  He got there by jumping off the yellow platform after pulling lever.  My Jack is such a accident looking for a place to happen.   ;D
15499
There are 2 gold coins in the clouds. How are they suppose to be collected?
Re: Mansion Comments: Mount Peril - Wingy - 04-11-2010
676E786E66660F0 wrote:
16301
This shall be fixed.
15499
There's a way, Missy, I'm sure you'll find it ... eventually. Wink
