Mansion Comments: Leofani Manor - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Mansion Comments: Leofani Manor (/showthread.php?tid=1313) |
Re: Mansion Comments: Leofani Manor - hawaii - 04-08-2010 HARD: Room 16300 If Jack goes down 1st ladder, kills the spider on bottom level, AFTER he pulled some levers, he re-appears behind the CLOSED panel door on the far left. Even if he leaves the room, the grey door remains closed. Room 16699 When Jack jumps out of the hidden spot past the last vine on the right upper corner, he doesn't grab the vine, he ends up on the zappers. Maybe he stood in the wrong spot, but still, grabbing the vine should be a lot easier. Re: Mansion Comments: Leofani Manor - rose - 04-08-2010 5F5640565E5E370 wrote: Easy: Room 16304 No, not a JS. I replayed the Leofani manor easy and started to enter in the same room. I found the key without problem. Maybe you should replay the mansion again.?! Re: Mansion Comments: Leofani Manor - hawaii - 04-08-2010 Hard 16301 Gosh, do I absolutely hate these types of puzzle rooms. I am totally stuck! Questions: #1 Does Jack enter this room with no keys. yes or no? #2 pls provide road map/instructions to p/u red key & get on with the game. I just checked this room in MLB TEST room & Jack is on the left side of the moveable grey column. Yet, in the game, I can't get him on that side to pull the lever to lower the grey panel with the red key!? I have spent over an hour on this area & I am very frustrated. Help please! Re: Mansion Comments: Leofani Manor - hawaii - 04-08-2010 75687462070 wrote: [quote author=5F5640565E5E370 link=1270280728/9#9 date=1270708036]Easy: Room 16304 No, not a JS. I replayed the Leofani manor easy and started to enter in the same room. I found the key without problem. Maybe you should replay the mansion again.?! Hi Rose, Thank you for trying to help, but I don't think you understood my point. I too found the EASY RED KEY IN ROOM 16301. But if you use that red key FIRST in Room 16304 RED DOOR to enter the puzzle rooms 16305 & 16306 then you are left without a red key to continue. I even checked in the MLB & there is no extra red key in these rooms to continue the game. So Jack is stuck, if he uses that red key on the door in room 16304 instead of another door in another room first. Re: Mansion Comments: Leofani Manor - rose - 04-08-2010 Hi Rose,No, you are wrong, Missy! You are right about that there isn't any red key in 16304, 10305 or 16306. You have to go down the pole in room 16306 and explore further. Re: Mansion Comments: Leofani Manor - hawaii - 04-08-2010 637E6274110 wrote:Hi Rose,No, you are wrong, Missy! You are right about that there isn't any red key in 16304, 10305 or 16306. You have to go down the pole in room 16306 and explore further. THANK YOU SOOOO VERY MUCH for the direct hint. I think that I am very burnt out from staying up real late testing. I think that I will just stop now until the updated versions come out. I really need the break.
Re: Mansion Comments: Leofani Manor - VernJensen - 04-08-2010 Don't burn yourself out testing, Missy! You've done some great testing so far, but it'll likely be 2-3 months until the game is ready to be released, so you've got time. ;-) Re: Mansion Comments: Leofani Manor - Wingy - 04-08-2010 484157414949200 wrote: Hard 16301 Ah, my bad. I guess I didn't test this enough. ![]() I just checked it, and it isn't possible to get through -- I'll make some changes for the next beta version to make this possible. Re: Mansion Comments: Leofani Manor - hawaii - 04-08-2010 17292E2739400 wrote: Thank you Anthony for letting me out of the twilight zone! ![]() Also, this section does remind me very much of one of the CM's I played last year. It too drove me nuts! ;D Vern, Thank You for pointing that out. I thought that we had to rush. whew! I was staying up until 3 am testing. Re: Mansion Comments: Leofani Manor - hawaii - 04-08-2010 Easy Room 16502 and perhaps in all the different modes. There should be a step for Jack to get out of there instead of using the down ladder. (my Jack was doubling back, he does NOT want to go down. |
