Mansion Comments: Dr Demented's Den - Printable Version
+--- Thread: Mansion Comments: Dr Demented's Den (/showthread.php?tid=1311)
Re: Mansion Comments: Dr Demented's Den - hawaii - 04-10-2010
Normal
Room 15503
Pls. check out floating head. Doesn't it come out chasing Jack to fast?  There is no lamp to kill it with and he does have to balance those conveyer belts...maybe a tad to much for normal???
Room 15907
There is a coin right on the snake, lower level, near green door.  There is no benefit to killing that snake, except a loss of Jack's life.  hmmm
Room 16506
Do you think that Jack entering this room quickly is a cheap death?
Re: Mansions being tested - TrixieB - 04-11-2010
Dr Demented Normal:
I got 100% of secrets and 20 000 points
I finished in just under an hour. Usually I lose all of my lives a couple of times before I finish a game on Normal and even sometimes on Easy. This game is fun, but very easy. Maybe too easy for Easy, but definitely too easy for Normal.
In room 15907 you cannot get the one coin unless you kill the snake.
No other glitches, or problems. Just a little too easy and a little too fast.
Re: Mansions being tested - Wingy - 04-11-2010
Actually, you can get that coin without dying... stand *right* next to it, then use your jump left key (default numpad 4) and you should get it as you jump over.
Re: Mansion Comments: Dr Demented's Den - VernJensen - 04-12-2010
[postsmovedhere1] 2 [postsmovedhere2] Tester's board [move by] VernJensen.
margherita,
The mansion's designer was Jacob Vann. Glad you liked it!
I'll look into the suggestions you posted.
0B0214020A0A630 wrote:
Room 15907
Yes, but there is also a shield in the very same room, behind the left column. You can see its outline pulse red. I'm pretty sure Jacob intended for observant players to see the shield, take it, and kill the snake with it for max money score. I'm inclined to leave it as-is. Thoughts?
51584E585050390 wrote:
Room 16506
Do you have the right room number Missy? I don't see how there could be a cheap death in 16506. How so?
Re: Mansion Comments: Dr Demented's Den - Semi-Native - 04-12-2010
1724332F0B242F32242F410 wrote: [quote author=0B0214020A0A630 link=1270280669/10#10 date=1270919873]
Room 15907
Actually, it is possible to jump over the snake and get the coin without dying, because I've done it. But the shield there also is a life saver. 8-)
