Mansion Comments: Blackheart Keep - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: 120 (https://actionsoft.com/forum/forumdisplay.php?fid=10) +--- Forum: 999 (https://actionsoft.com/forum/forumdisplay.php?fid=55) +--- Thread: Mansion Comments: Blackheart Keep (/showthread.php?tid=1308) Pages:
1
Re: Mansion Comments: Blackheart Keep - VernJensen - 04-08-2010 Alan -- Just watched your movie. Did make note of a few rooms I should probably make a little easier on Normal. Thanks. If you do run across more specific suggestions you want to write out, I'm all ears. :-) Re: Mansion Comments: Blackheart Keep - VernJensen - 04-08-2010 6A6675606F62756E73663133070 wrote: Hi Vern, I have not explained well. Ahhh, okay. Thanks for explaining. I think I will leave the mansion as-is. I didn't create this mansion, but it looks like the blue key you didn't get initially is meant to be a secretkey of sorts -- one that, if you get it, you are rewarded with additional treasure that you would otherwise not get. Some see this as incentive to play the mansion again to find *all* the treasure the next time. Re: Mansion Comments: Blackheart Keep - VernJensen - 04-08-2010 Missy -- Have just finished fixing the last of the bugs you reported. Good thorough testing! Re: Mansion Comments: Blackheart Keep NORMAL - rose - 04-10-2010 I have played through it twice without finding the last yellow key for the yellow door in room 16297. A hint please. I have tried to find the keys in MLB but the map is always so small so I can't see the details. (One reason to that I don't try to build mansions myself, I need to see that map clearly) I haven't so far seen any real problems. I do hate though when there is both yellow bricks and checkered bricks moving, to may bricks for a Normal version. Re: Mansion Comments: Blackheart Keep - captainivey - 04-12-2010 Just finished playing through the mansion on normal. Overall I thought it played at normal level. There were a couple of challenging sections but I didn't think they were too challenging for normal. Good mansion and no bugs that I found. Re: Mansion Comments: Blackheart Keep NORMAL - VernJensen - 04-13-2010 7865796F0A0 wrote: I have played through it twice without finding the last yellow key for the yellow door in room 16297. A hint please. I have tried to find the keys in MLB but the map is always so small so I can't see the details. (One reason to that I don't try to build mansions myself, I need to see that map clearly) The new editor tells me yellow keys are in these rooms: 15495, 15694, 16094, 16099, 16294 There are 6 yellow keys, so one of the rooms above must have 2. If the game needs to hintbetter as to one of these secrets, let me know which you think needs a more obvious hint. Although, I think part of the fun of exploring is finishing a mansion, and wanting to get a perfect score, and having to figure out just what you missed, and where! |
