Everybody busy playing "Les Catacombes Rouges - Printable Version
+--- Forum: Les Catacombes Rouges (https://actionsoft.com/forum/forumdisplay.php?fid=108)
+--- Thread: Everybody busy playing "Les Catacombes Rouges (/showthread.php?tid=1080)
Re: Everybody busy playing "Les Catacombes Rouges - Wingy - 03-24-2009
*spams buttons*
You sneaky fool............ Tongue
Re: Everybody busy playing "Les Catacombes Rouges - Wingy - 03-25-2009
That took a while to do, so many game overs... ouch. I had 0 lives left when I entered the winning room.
Was a quite enjoyable (*COUGH*) mansion there AquaMat. This is definitely another Aquamat-styled mansion.
Here where my cons of the mansion:
Many, many... many... deaths occurred from your evil tricks. Most were unfair and really hard to get out of. (E.g. you are holding down your movement key from a room and you fall off a cliff in the next with only 1 tile brick in the next room between you and the cliff) Those have happened to me plenty of times.
Rooms with things such as a moving platform and a bowl of lava which you have to jump across from the moving platform and is constantly bouncing around can be quite ... annoying. Many players (especially older ones) only can test their luck and have a 50-50 chance to get it right.
Your sneaky way of hiding things was quite confusing, took me so long to look around for it, but when I found it I died and just opened a save therefore reducing time. The total gameplay time if I didn't open saves, probably 2-3 hours.
Nevertheless the mansion is quite enjoyable the way it is; I'm not asking you to change anything just giving you my thoughts.
It definitely was hard, but after you won, you get to brag about it on the forums with screen shots. Tongue
Overall, I really liked it.
Will look forward to more work from you.
(Only 62% secrets! I fail Sad )
Re: Everybody busy playing "Les Catacombes Rouges - SandyBean - 03-25-2009
Wingy,  You Didn't Fail !!!  You got through the mansion, so you Won!!! [smiley=vrolijk_26.gif]
Yes, aquamat's mansions can be hard and sneaky, but that's what keeps us
older
ones going !!!   [smiley=thumbsup.gif]
BTW; what is 'opening saves' ?!?!?   :-?
Can't wait for both you and aquaMat to make more mansions!
SandyBean [smiley=2vrolijk_08.gif]
SandyBean wrote: BTW; what is 'opening saves' ?!?!?   :-?
You know, when you get the GAME OVER screen and have to click the
Open Game
button on the menu and select your last save file.
Re: Everybody busy playing "Les Catacombes Rouges - SandyBean - 03-27-2009
OK, thanks Wingy, I get it now.  You go through the section, figure out what to do, maybe lose a few lives, and then open at your last save point to spare some time, already knowing where to be careful.
Thanks for explaining, I just thought this was a special way of making new save points that I had not heard of yet.
