MM2 - Brave New World - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: General Custom Mansions Area (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=4) +--- Forum: Free Uploading and Downloading (https://actionsoft.com/forum/forumdisplay.php?fid=19) +--- Thread: MM2 - Brave New World (/showthread.php?tid=2204) |
Re: MM2 - Brave New World - brell - 03-07-2023 1A2E393838255C0 wrote: Found the way into room 17500. I recalled something from the ultimate maze in MM&M. But isn't this a bit too hard for an inexperienced player to discover? Perhaps a hint is needed? Finished with 14 secrets. Re: MM2 - Brave New World - Freddy - 03-07-2023 5343545D5D310 wrote: Found the way into room 17500. I recalled something from the ultimate maze in MM&M.Nothing wrong with your memory! The idea came indeed from that exhausting maze. I thought that the existing of the conveyor belt was enough as a hint (besides the obvious gap in the wall). As you know I try new things as hint. I want players to search for odd things. So what is that belt doing there? Assume that there is a room at the right, where may Jack enter it? At last 'where' is supposed to change in 'how' since a jump from the ghost platform to the conveyor belt is impossible. (Btw, I can't change the 6-tile gap into 5 or less, because then it makes the belt completely senseless.) I have an idea for something extra (that is not a coin or an other reward). 5343545D5D310 wrote: Finished with 14 secrets.Two missing. Have you read the sign in the blue area about a secret room? It may be of interest to do that if you didn't yet. I don't know what the other missing secret could be. Therefor I must dive into the builder. Do you remember the total amount of money at the exit? Re: MM2 - Brave New World - brell - 03-08-2023 192D3A3B3B265F0 wrote: [quote author=5343545D5D310 link=1671814205/90#90 date=1678195370]Found the way into room 17500. I recalled something from the ultimate maze in MM&M.Nothing wrong with your memory! The idea came indeed from that exhausting maze. I thought that the existing of the conveyor belt was enough as a hint (besides the obvious gap in the wall). As you know I try new things as hint. I want players to search for odd things. So what is that belt doing there? Assume that there is a room at the right, where may Jack enter it? At last 'where' is supposed to change in 'how' since a jump from the ghost platform to the conveyor belt is impossible. (Btw, I can't change the 6-tile gap into 5 or less, because then it makes the belt completely senseless.) I have an idea for something extra (that is not a coin or an other reward). Perhaps - as an afterthought - the belt and the gap is hint enough? 192D3A3B3B265F0 wrote:Two missing. Have you read the sign in the blue area about a secret room? It may be of interest to do that if you didn't yet. I don't know what the other missing secret could be. Therefor I must dive into the builder. Do you remember the total amount of money at the exit? Yes, I read that sign but I am not sure which room you are referring to. I must try again. €17.400 Re: MM2 - Brave New World - brell - 03-08-2023 Regarding 17703: Perhaps you can make it impossible for Jack to make a suicidal jump from the top of the silver bricks? Then the problem is solved I believe. You could use the T to make platforms appear to the sides of the silver bricks or something like that. Re: MM2 - Brave New World - Freddy - 03-08-2023 And you are also still missing a second secret. Have you been back to the room with the four giant spiders and the four fast moving eye balls? To have closer look ... Re: MM2 - Brave New World - Freddy - 03-08-2023 5C4C5B52523E0 wrote: Regarding 17703:I thought about that, but there is also the platform where the G/S-lever is. Jack may die there as well and the right side can't be closed because it's a 'landing' platform. Re: MM2 - Brave New World - Freddy - 03-09-2023 6D7D6A63630F0 wrote: ... Perhaps - as an afterthought - the belt and the gap is hint enough? ...I believe that we are on the same wavelength. The hints for the secret feel okay and normal. But 'play' is on the edge of hard. So wat I yesterday had in mind, you may see now in the image. Room 17499 is still under maintenance but I used ten spare minutes for a few changes starting with a safer ledge in the upper left corner. There Jack's progress to the red key is with the short ladder. And that is supposed to be a reminder or a lesson as help for what is going on at the other side of the room. The added lever helps Jack out of the left lower corner . Re: MM2 - Brave New World - Freddy - 03-09-2023 Regarding room 16703, this is what I am going to do (and see if everything works). - Replace the silver blocks with gold blocks and allow jumps to the left because of that gold coin. - Remove the 3 gold blocks left of the lever. And the lever itself. - Create a G/S-changer in the room above. - Install a way back ladder from the lower left corner in the room above to the upper left corner of 16703. - Add the blue key on that ladder to expose that Jack has to go up and down with one way ladders. - In the room above, add a second door in the lower left corner activated with a press button in the upper right corner. Re: MM2 - Brave New World - brell - 03-09-2023 083C2B2A2A374E0 wrote: Regarding room 16703, this is what I am going to do (and see if everything works). Are you sure you are not referring to 17703? Re: MM2 - Brave New World - brell - 03-09-2023 093D2A2B2B364F0 wrote: And you are also still missing a second secret. Have you been back to the room with the four giant spiders and the four fast moving eye balls? To have closer look ... OK found it. Very subtle 8-) |
