At last! Discotheque Of Doom ins running for me... - Printable Version +- Midnight Mansion Forums (https://actionsoft.com/forum) +-- Forum: General Custom Mansions Area (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=4) +--- Forum: MM1 HD talk (Mac and Windows) (https://actionsoft.com/forum/forumdisplay.php?fid=27) +--- Thread: At last! Discotheque Of Doom ins running for me... (/showthread.php?tid=2013) |
Re: At last! Discotheque Of Doom ins running for me... - rose - 05-18-2012 Right now I don't have it either. Could it be you/we have it just for a short time and then we can't correct the post any longer? I got the Modify option after I posted this message Re: At last! Discotheque Of Doom ins running for me... - aquaMat - 05-18-2012 Rose, no, I don't think that that's it. I did NOT have it immediately after I had written the post. Also I remember to be able to edit posts of mine that were written days / weeks ago. Must be something else.... But strange to hear that it disappeared for you too ! Did you log-out in the meantime ? Re: At last! Discotheque Of Doom ins running for me... - rose - 05-18-2012 I logged out I think when I leave the forum. I get always logged in automaticaly when entering the forum. I entered by clicking in the notification mail for this thread. I didn't have any Modify. I replied and when the I posted message I got the Modify option. D-n the font size is so small in the Reply window now, 6pt. I didn't do that!! Re: At last! Discotheque Of Doom ins running for me... - RobSeegel - 05-18-2012 aquaMat - yes removing the log in automatically from your other machine would probably help. Personally I just use the update session tab when it happens to me, since I often log in from different machines it's become pretty much automatic for me. The forums asks for a bit of info (not my password), and everything is put back. Re: At last! Discotheque Of Doom ins running for me... - brell - 05-18-2012 This is very simple: If you are logged in and then log in from a different IP while still logged in from the first one you'll have to update your session because otherwise the YaBB doesn't know which one to serve: The first or the second IP. If you log off from the first IP and then you log in from a different IP you don't have to update your session because then the YaBB only sees you on one IP. This has nothing to do with the logged in for keepsfeature. I often logged both at home and at work and then I had to update my session. After I started logging off at home after each session I do not have to update my session when I log in at work. Re: At last! Discotheque Of Doom ins running for me... - RobSeegel - 05-18-2012 4C5C4B42422E0 wrote: This is very simple: You're right assuming that you are logging in / out all the time. Like aquaMat, I normally don't, so often just update my session. It's easier for me. As with nearly everything, experiences and preferences may vary. Re: At last! Discotheque Of Doom ins running for me... - aquaMat - 05-23-2012 637E6274110 wrote: That same thing happened to me, too. I had complained about it somewhere else on these pages.... And the worst part: Although there IS the small Text sizefield at the right corner below the text field, where one can change it back from 6 pt to something more readable... IT ALWAYS RE-SETS ITSELF TO SMALL - so the next time I post something it is again 6pt and my eyes are starting to hurt. Who the hell allowed a software to boss us users around ?? ![]() We should be telling the software how to behave - not the other way 'round ! Re: At last! Discotheque Of Doom ins running for me... - aquaMat - 05-23-2012 @ Rob & brell: Thank you both for your comments. I can see clearly now. I'll try to log-out from my old Mac, so I then can stay logged-in from my MacBook, as I'm using that much more often. However, that update sessionfeature seems a quick + easy solution too - I have never tried that... not once in all those years. Maybe I will try that right away now - just to see how it works. Thanks !! Re: At last! Discotheque Of Doom ins running for me... - aquaMat - 05-23-2012 Did Update Sessionand -boom! - MODIFY button reappeared instantly! That was easy! Thanks again. Re: At last! Discotheque Of Doom ins running for me... - aquaMat - 06-09-2012 @ Rose, brell, Rob: Even though the MODIFY - button did re-appear for me after I had done the Update Sessionthing described by Rob & brell (see below), it had disappeared again very shortly after. My assumption was that the reason for that was that I still was logged in from my old G5's IP address - even if I hadn't accessed the forum from there in the meantime this probably still mattered. So I have finally logged out from the forum using my old G5 yesterday.... leaving this IP-address (my MacBook) the one that is logged in for keeps. BUT: Still the MODIFY button does not show!! (I have just posted an entry in another thread). I will try now once more to Update (the) Session..... maybe afterwards it finally gets back to its normal behavior ??!
